: 1 ... 3 4 [5]
: Robs 1967 FJ40  ( 32069 )
« #60 : June 24, 2011, 01:31:34 PM »
Looking great!  8)
Gerhard Bolt
Newbie
A man is only as big as the dream he dares to live
« #61 : June 24, 2011, 04:49:42 PM »
How many J4’s do have? Clearly there is a 44 in back ground…. Another 40 or 45 to the right? She looks really great!  8)
What do you dislike about the 7.50 16” tyres??? It looks like Dunlop Universals. I’ve just bought a set of Universals for my 40 because the 30” BFG’s are too small and I really like the old school look.  |(
'72 FJ45 (F155 with 3-speed gearbox)
BMW 650 X Rally
Rob Wright
« #62 : June 25, 2011, 11:25:00 AM »
 Gerhard ,Only got 3 x 40,s but still looking to add  ;D.
 The one in the far backround is FJ 45 RV station wagon and the other my BJ 42 ,both
 needing rebuilds .You correct those tyres dunlop universal,s but mine made in Zim so
 maybe fit for a scotch cart only . as 1 cant balance they so out of round .I do agree they look the part ,but IMO those skinnies fine for serious terrain ,but impractical ,unreliable ,uncomfortable,
for our general use ,Old technology .My rims not splitties ,are the original so to get the bead on a crossply over its PT ,hoping to use my orig rims and hubcaps for the BF muds . :)
Trevor Roux
« #63 : June 28, 2011, 07:26:47 AM »
Looks great ;) :)
Trevor"tiger"Roux
76 FJ40 "TURBO TURTLE"           FJ 40 WP
77 FJ45 "ZONJA"                        CN6300
06 4500 EFI GX "TIGERTOY"       CN 10000
10 4500 EFI P/U "DIE OORSAAK"  CN 3600
Dane Read
Jr. Member
« #64 : July 05, 2011, 09:11:01 PM »
Hi rob
Do you know if that Greek guy called zorba is still around.
He rebuilt 2 cruisers for my uncle in kadoma back in the day.
Build looking great Btw.
We really struggle here in bots to get some of the basics (sandblasting, powder coating, engineering, lack of a decent trust worthy mech) we were saying the other day. We would be better off in Zim. At least we could pop into Bobby hawks workshop and get some stuff done.
2009 Hilux 3.0D4D S.Cab
1981 BJ44V
2009 Prado 150 D4D
Rob Wright
« #65 : July 06, 2011, 09:05:06 AM »
 Dane .
 Yes Zorba the Greek still around as far as i know .Think he makes bread now instead of
 rebuilding Cruisers .Understand your predicament in Bots ,The best is buy a decent Manual and do the mechanical work yourself ,If you mark everything and do stage by stage ,and take photos if you not sure .It can be done and very rewarding .Big Advantage with these old cruisers they are very very simple .And always lots knowledgeable and helpful people here on the Forum to assist when all else fails .Zim also a mission to get any outside work done .All the Artisans seem to have left ,I end up doing nearly all my work here myself .
 Your Build looking Great ,Just persevere and enjoy it , :)
Andy Lockley
Newbie
« #66 : July 14, 2011, 02:58:06 AM »
Hi Dane
I used to live in Gabs for a number of years so I might be able to provide you with some contacts for mechanics and engineering work. I still have some friends there who would be able to provide you with some up to date information. There was a German mechanic who was very good who bought my friends Patrol when he left apparently he was very good. I shall try to find out his name. If I needed help with any mechanical work I used a guy called Aaron a ZA mechanic he was based in Broadhurst Industrial estate up near the printers. Not sure where to suggest for sandblasting I would contact the paint supplier also in Broadhurst Ind. If you are chasing a Toyota manual I can look for you over here in Aus.
Andy
1984 BJ42 LX
Dane Read
Jr. Member
« #67 : July 14, 2011, 10:24:14 PM »
Thanks andy. I will try and find Aaron tomorrow.
We have one guy who is very good with cruisers. He stripped and sprayed our engine.
However is is very busy in the week at work and only has weekends available. Not so easy to pin him down. Very Clued up guy though. We just so desperate for a good reliable family mech in Gabs at the moment.
Apologies for jacking your thread Rob!
1981 BJ44V
2009 Prado 150 D4D
Rob Wright
« #68 : July 21, 2011, 08:15:46 PM »
 Removed rear diff ,fitted new bearings the rest all good . reset preloads and backlash and fitted speedy sleeve and new seals on pinion and halfshafts .
 Fitted new Dobinson rear sprongs ,drilled and fitted friction pads to spring blades .
 Stripped front axle down ,fitted new swivel bearings and birfield seals .
 Interesting No Birfied seals on this axle .and note old style side shafts .No oil was evident at all in Birfields on stripping so this set up does work .
Rob Wright
« #69 : July 21, 2011, 08:23:44 PM »
 Preloads all done .
 Battling to find front hub seals ,different size to later models .might have to fit
 pirate .
« : July 21, 2011, 08:25:44 PM Rob Wright »
« #70 : July 21, 2011, 09:37:16 PM »
Good and clean and fresh.
Dane Read
Jr. Member
« #71 : July 21, 2011, 10:36:30 PM »
Nothing like fresh new front hubs.
Diffs etc is one thing that we have not done on our 44. Mechanically though there did not seem to be any major problems before we stripped.
What is your reason behind opening your diffs I see most of the guys doing it. Was there an obvious problem with it? Or is it just a must do routine task?
I was thinking about our rear dif yesterday. LSD and all. What do u think would be our best solution. How would I go about testing if all is OK inside?
1981 BJ44V
2009 Prado 150 D4D
« #72 : July 22, 2011, 01:27:45 PM »
Looking very good Rob !  8)
« #73 : July 24, 2011, 03:21:14 PM »
Rob - your Birfield is completely different to both mine
yours is the old "Claw type"
1st time Ive seen one
Rob Wright
« #74 : January 20, 2013, 09:42:51 AM »
Eventually got a rim for the spare,as per the originals .Schalk from N1 4x4 kindly sourced and procured it for me .Needs a Sand Blast and a coat of paint and fit the new BF mud  :) still need to try and source a set of hubcaps like Adolfs and PS,s .
: 1 ... 3 4 [5]
