: [1] 2 3
: Aussie LRT rear axle snag  ( 19543 )
« : October 01, 2013, 10:49:09 AM »
How many late model 40s, as in late enough to have the handbrake located on the rear axle with Aussie LRT tanks fitted are on this forum ? Of those, who have the 5sp box ? Does your axle knock against your LRT when flexing hard ? It seems this problem is not uncommon in Aus on LX models, as the tanks wetre designed for earlier models ie 4sp and handbrake in the TC ?? Common fix seems to be BFH  :o
« #1 : October 01, 2013, 12:13:49 PM »
Pics?  ???
« #2 : October 01, 2013, 12:49:33 PM »
Will snap some when I get home JT. I was very surprised to hear that this was a "known" problem in Aus
« #3 : October 01, 2013, 01:52:34 PM »
Keith has a 4spd and Mark and Adolf don't go off-road enough to have experienced the problem  >:D
« #4 : October 01, 2013, 02:35:04 PM »
I think Kermit's handbrake is not on the axle though, not sure about Darth Vader ? Would like to see his clearance.OD has huge bumpstops and I have never measured/ compared a "4sp" vs "5sp" chassis before  ???
« #5 : October 01, 2013, 06:32:00 PM »
Kermits handbrake is on the propshaft
DarthVaders handbrake is on the rear drums, but it hasnt done any axle twisting yet
But Ill have a close look
« #6 : October 02, 2013, 08:35:52 AM »
The chassis at the rear are the same, the late model ones had some changes to the front spring mounts...
...but it comes down to whether you have a transmission or an axle mounted hand brake.
I am guessing bumpstop's are the answer at the expense of rear articulation
« #7 : October 02, 2013, 09:22:23 AM »
Never happened on mine and will also not happen. Space between tank and axle is ample enough!
« #8 : October 02, 2013, 10:09:32 AM »
Could also be spring pack design, length from the fixed point.
« #9 : October 02, 2013, 06:13:58 PM »
« : October 03, 2013, 02:22:51 PM Adolf Hüster »
« #10 : October 02, 2013, 06:17:26 PM »
Why is that pic so big?!  >:(
« #11 : October 03, 2013, 05:47:04 AM »
because its a BEEEEEG tank for a BEEEEEEG country  ;D ;D
« #12 : October 03, 2013, 11:58:31 AM »
Thanks for the feedback sofar.I have not forgotten and will take pics tonight.Adolf I bumped when both wheels hit potholes/ditches together not when flexing in axletwisters.Will try to find some big axletwisters this weekend to see what happens but sofar it seems it is only when both wheels flex upwards and rearwards with the springs.JT the others all seem to have been OME suspensioned 40 ser trucks and never an OEM susp so you might be on to something  ....
« : October 03, 2013, 06:04:37 PM Theo Marx »
« #13 : October 03, 2013, 02:23:31 PM »
Piccha modified.
Theo, you hit two potholes at the same time with rear wheels?  :-\
Understand if there are plenty oles, but they are also not in line, or very seldom.
I very much doubt that my axle will reach LRT if it is bumped backwards, off course the
bump stops would help in that case, but then I would also hit the wheel arches, same with the flex.
« : October 03, 2013, 02:47:13 PM Adolf Hüster »
« #14 : October 03, 2013, 06:09:42 PM »
Yes Adolf.The roads in the Cedarberg are currently the worst I have ever seen.There were constant ditches/rivers running across the roads and huge potholes everywhere. Anyhow here are the pics- truck still dirty so ...
: [1] 2 3
