« #15 : October 03, 2013, 06:56:59 PM » |
Don't think they have changed the axle distance from 4 to 5 speed. Maybe measure the spring length from fixed point. I can measure mine tomorrow.
Adolf My Collection! FJ40 2F 1982 / FJ43 V8 1975 / FJ45 2F 1978 FJ55 2F 1980 Barn Doors / FJ55 2F 1979 Tailgate BJ74 13BT 1988 / FJ62 4.5EFI 1988 For Trips: 100 VX TD 2001 / 78 1HZ (soon 1HDT) Troopy 2011
« #16 : October 03, 2013, 10:48:14 PM » |
Nice picture of the Moon and Stars Adolf.
« : October 03, 2013, 10:50:26 PM Grahame Burchell »
« #17 : October 04, 2013, 06:40:32 AM » |
Huh?!
« #18 : October 04, 2013, 11:10:00 AM » |
Theo
You know what couldve happened. You put the rear springs back in front to back Cos they have a clear long and short side from the axle mount
Might be worth double checking
FJ40-1979 TARSUXGP FZJ105-1999-TOY100GP FJ40-1983-LX-ELLEX FJ Cruiser 2011 BM81KT-GP KTM 1190 Adv Ducati Multistrada 1200 KTM 990 SMT MV Agusta Brutale 920 Kawasaki Z1000J ELR Honda CB900F
« #19 : October 04, 2013, 12:05:30 PM » |
I will check it again Keith but it is unlikely, as it is a known issue with LX models in Aus. I will probably relocate that bracket and nut to the bottom but that still leaves the other one on the 3rd member. BFH might be the only tool
11/83 UZJ 42 LX with some goodies : Olive 06/99 HZJ 75 RV
« #20 : October 04, 2013, 06:52:46 PM » |
Why is it a problem with the LX only? All Axle's and their position should be the same on all models from say '80 onwards.  I had my tank in from the beginning, done the Legend Trip loaded, checked again today, not one scratch on the tank.
« #21 : October 05, 2013, 10:38:17 AM » |
Never had a problem like this. Clearance same as in OD's pics. plenty of clearance on mine, and have done a fair amount of axle twisting. what I have not had yet is the entire axle moving up to the bump stops at the same time. I will also check when I am back in SA...
2006 LC 79 EFI 2000 LC 100 VX TD 1982 LC FJ 40
« #22 : October 05, 2013, 12:30:27 PM » |
and have done a fair amount of axle twisting Pics - or it didn't happen
« #23 : October 06, 2013, 04:06:21 PM » |
Theo, see your shackle angles.
« #24 : October 07, 2013, 08:24:44 AM » |
What about them Adolf ? I think it only effects late model 40's with earlier model tanks, and only if heavily loaded and when the susp bottoms out on both sides ie the axle travels backwards and upwards.This weekend she didn't touch once even though at 1 obsticle I hit the front and rear bump stops at speed  - although she was not loaded at all.
« #25 : October 07, 2013, 09:25:18 AM » |
Does not look right to me. Play almost finished! Especially on front. Wonder if the Hellcreek's are not longer, hence your problem with the tank. Did you remove a spring?
Your rear wheel seems to be further back then on mine!
« #26 : October 07, 2013, 10:45:58 AM » |
 That is an action pic taken while we are racing up a rather steep dune ( 2nd last obsticle for the day where few vehicles made it up at the first go ) so don't expect the shackle angle to be at a stationary 45 deg, besides the front shackle angle will have no effect on the rear tank etc. I did not remove any springs and suspect the Hell Creeks are just nice and flexy compared to most others.I have noticed some body roll in fast corners so maybe my shockies have lost some dampening also
« #27 : October 07, 2013, 12:40:50 PM » |
That is an action pic taken while we are racing up a rather steep dune ....  I can see that, but it is already on a straight!  And your wheels are still far away from the wheelarches, so what I mean is shackle angle compared to wheels in arches!  Anyway, hope you find your problem! Glad I don't have it!  Btw, your bushes should be with JB!
« #28 : October 07, 2013, 02:21:19 PM » |
« : October 07, 2013, 02:50:53 PM Theo Marx »
« #29 : October 07, 2013, 06:32:03 PM » |
Send pic of stationary cruiser to compare.  JB was too skaam, because the bushes are pink!
