« #30 : October 07, 2013, 06:36:13 PM » |
« #31 : October 07, 2013, 10:41:02 PM » |
Theo
In that pic of you going up the dune, it appears that your axle/wheel is too far back in the wheelarch
I reckon your leafs are in back to front
« : October 08, 2013, 10:27:46 AM Keith Richardson »
FJ40-1979 TARSUXGP FZJ105-1999-TOY100GP FJ40-1983-LX-ELLEX FJ Cruiser 2011 BM81KT-GP KTM 1190 Adv Ducati Multistrada 1200 KTM 990 SMT MV Agusta Brutale 920 Kawasaki Z1000J ELR Honda CB900F
« #32 : October 08, 2013, 09:07:25 AM » |
I will measure Keith but I doubt they are the wrong way around.It is more plausable that the 4" Hell Creeks are longer from the fixed point to the centre locating pin of the spring perch.I remember reading that Tom from Hell Creek at a stage lengthened the 40 ser springs to improve flex and ride. Adolf this is a pic where she is heavily loaded and towing.You can see the shackle angles are at about 60 deg IOW 15 deg more than the 45 deg which is regarded as the holy grail of shackle angles.  I went through some serious cross axles on Sat and never touched once.However going up Klippies really hard we did hit what I though wwere just the bumpstops but visual confirmation proves we did hit the tank again so it is clear it only happens when the suspension on both sides bottoms out and the whole axle travels upwards and rearwards.Maybe I should just have the tank cut & welded in that area ..
11/83 UZJ 42 LX with some goodies : Olive 06/99 HZJ 75 RV
« #33 : October 08, 2013, 09:53:36 AM » |
Too me those shackles lean too much.
Adolf My Collection! FJ40 2F 1982 / FJ43 V8 1975 / FJ45 2F 1978 FJ55 2F 1980 Barn Doors / FJ55 2F 1979 Tailgate BJ74 13BT 1988 / FJ62 4.5EFI 1988 For Trips: 100 VX TD 2001 / 78 1HZ (soon 1HDT) Troopy 2011
« #34 : October 08, 2013, 10:29:27 AM » |
Theo
Maybe you should measure your wheelbase and we can compare it with ours But I dont have any problems with Kermit
« #35 : October 08, 2013, 07:37:43 PM » |
Ok measured rear springs and they are not flipped - front spring eye to locating pin is 53 cm and rear spring eye to locating pin is 65 cm.Wheelbase is 226.5 cm
« #36 : October 08, 2013, 09:04:28 PM » |
I'll measure Kermits wheelbase
what does the spec sheet say re Wheelbase
« #37 : October 09, 2013, 12:19:21 AM » |
Right - stock the axle centerline is 500mm from the centre of the fixed pin, so measure from the the pin in a straight line back to a perpendicular line that bisects the centreline of the axle. This measurement is the important one as lift springs will be longer if you measure along the length of the spring.
FWIW the stock SS of both front and rear springs is 505mm and the LS is 605mm, spring length is 1110mm and wheelbase is 2285mm (90") so if anything Theo's is a little short.
One other thing the distance between the centre of the pin eye and the shackle hanger is 1070mm both front and rear on early models and 1060(front)/1070(rear) on late models, they did this to make the ride less harsh by flattening the shackle angle in the front - by moving the front shackle hanger back 10mm
« #38 : October 09, 2013, 08:24:51 AM » |
I measured in the dark and measured along the spring blade so ....
« #39 : October 09, 2013, 09:40:42 AM » |
... SS
« #40 : October 09, 2013, 12:26:32 PM » |
SS = Short Side LS = Long Side
« #41 : October 09, 2013, 12:49:16 PM » |
SS = Schutzstaffel
« #42 : October 09, 2013, 01:06:12 PM » |
 In Theo's case 'Short Staffel' , now with Pink Bushes!
« #43 : May 22, 2014, 09:03:33 AM » |
LRT was fitted incorrectly by PO and I now understand why .. Instead of the tank's rear mounting lip resting ontop of the chassis crosmember, my PO had it hanging from underneath.I have now slotted the holes more towards the tank (ie forward), fitted some longer U-bolts and shortened the tank's filler neck, thereby lifting the tank higher and upwards towards the tub to create space almost like a pendulum.Early indications are that I have created so much space that I will no longer have a problem.Dropping the tank in while the tub is in place does require some trickery though ..
