Hi there
Need some newby help here...
I did a first engine 'service' by changing oil, oil filter, air filter, flushing radiator and also changed the fuel filter.
It is a HJ45 H diesel engine (3.6l 6cyl)
I started her up, not knowing that the fuel line needed to be bled after changing the fuel filter, she only ran nicely for a couple of seconds then died.
Consulting my manual it states that the air needs to be removed by opening the bleeder screw on top of the fuel filter and pumping the manual pump on the fuel feeder. Here's the problem - there is no such bleeder screw on my fuel filter - see below.
Is this normal? Where do I bleed out the air now?
I tried this bleeder screw on the injection pump.
It took some manual pumping before the fuel started coming out - but still no joy for starting her.
What's next?
