: HJ45 vacuum pump  ( 2164 )
Eric Guldemond
Newbie
« : July 25, 2014, 09:54:24 AM »
Hi There
I suspect my Cruiser to not have sufficient vacuum to the brake booster.
Symptom is that when I pump the brake pedal while engine is not running then it becomes stiffer as it should, but then holding the pedal while starting the engine and revving it a bit there is no movement in the brake pedal at all.
I removed the vacuum hose from the vacuum pump and do feel a bit of suction but nothing major. How hard is it suppose to suck?  :-\
-e-
« #1 : July 29, 2014, 09:09:14 AM »
Eric, it does not feel that hard if you block the pipe with you finger, but I put a vacuum gauge on mine last week and it read 27'5" vacuum. you need to get it tested.
Eric Guldemond
Newbie
« #2 : July 29, 2014, 02:11:09 PM »
Thanks Grahame, like you suggest - I'd rather have it tested  :)
