: Strange rear axle seals on BJ40  ( 3718 )
« : July 07, 2009, 03:24:14 PM »
When we stripped Egberts axles I found the rear axle seals were completely different to my 40
I then searched my manuals and toyodiy back to 1976 and couldnt find this type of seal anywhere
The axle seal actually sits inside the wheelbearing retainer nut - very strange, whereas on all other 40's this seal sits on the inside of the axle tube.
As I was concerned that the diff oil would migrate out into the wheelbearing grease through the threads of the wheelbearing retainer nut - I covered these threads with silicon gasket sealer to prevent this.
« : July 07, 2009, 03:32:19 PM Jonathan Tee »
« #1 : July 07, 2009, 03:47:17 PM »
Found another pic on MUD
But the oil seal in the rear on mine is inside that nut. The whole assembly is NOT available from Toyota, but I got the actual oil seal (which just presses into the nut itself) from SOR.
And the new axle seals are in, but here's a picture of the 75-80 FF hub nuts--the ones with the integral seals.
« : July 07, 2009, 04:06:36 PM Jonathan Tee »
« #2 : July 09, 2009, 02:45:20 PM »
I read through my manuals and the Haynes one has this type of seal in their diagrams, the others have the more common ones.
« #3 : July 09, 2009, 04:34:17 PM »
Will this last and sustain the heat?? Special sealer ??
« #4 : July 09, 2009, 06:00:04 PM »
Definitely - the sealant is rated at 180 deg there is no way this will get anything above 80deg and there is no rotation or friction to worry about
« : July 10, 2009, 07:33:04 AM Jonathan Tee »
