: Tapping the Diff Housings for ARB Lockers  ( 2156 )
« : July 17, 2009, 03:29:42 PM »
To fit ARB lockers, you need to drill and tap the Diff housing for the air supply for locker activation.
Step 1: Make a punch mark where you want to drill
Step 2: Drill a pilot hole with a small drill bit +- 3mm
Step 3: Drill the final hole to the size indicated in installation manual
Step 4: Insert the correct size tap, and lubricate with light oil or cutting fluid
Step 5: Rotate the tap to cut the thread to desired depth
Step 6: Clean the area thoroughly
Step 7: Test fit brass fitting
« : September 02, 2009, 10:42:17 AM Jonathan Tee »
« #1 : July 18, 2009, 02:40:30 PM »
JT
recommendation;-
Put some silicon sealer or PTFE tape on the thread - it will help to prevent diff oil seepage over the long term.
Mark Seele
« #2 : July 21, 2009, 07:52:54 PM »
Or something like Hermitite Red - non hardening gasket sealer?? Thanks JT, steady hands required to ensure hole is "straight" in when drilling or is this not mission critical? :-\
2006 LC 79 EFI
2000 LC 100 VX TD
1982 LC FJ 40
« #3 : July 27, 2009, 07:58:23 AM »
Used Wurth 250 silicone
« : September 02, 2009, 10:42:28 AM Jonathan Tee »
