: [1] 2
: Late model front spring seat Question?  ( 6507 )
« : July 23, 2009, 12:12:45 PM »
Anyone know what is the correct orientation of this, I think they were fitted wrong by the PO, so which is correct way forward and correct side for the one in the picture?
Anyone know why they have a plate built in, like a castor plate, but should have no effect as is it is on the bottom of the spring, and not between the  spring and the axle.
« #1 : July 23, 2009, 12:32:46 PM »
JT
I was correct, narrow portion to front
flat section to wheel
« #2 : July 23, 2009, 12:42:35 PM »
Eish check that rust...  Interesting that Toyodiy has it different as best I can see:
« #3 : July 23, 2009, 12:49:36 PM »
Well - by the looks of ELLEX those sprongs are so flat that they have never been off
and all shockles and pons are also still stock standard
« #4 : July 23, 2009, 12:53:49 PM »
Will prob mount the way you suggest irrespective of the Toyodiy diagram.  That was they will be the same orientation as the rears
« #5 : July 23, 2009, 12:56:17 PM »
I didnt take a pic of the rear but I did check - it is also narrow side forward and flat side to wheel
« #6 : July 23, 2009, 12:58:06 PM »
Has to be for the shock mounts ;)
« #7 : July 23, 2009, 01:59:57 PM »
A pic from Andre confirms it... will go this route
« #8 : July 23, 2009, 06:00:45 PM »
Why didn't you look at mine when you were here ? :jt:
 Keith is correct   ;)
« : July 24, 2009, 08:10:03 AM Theo Marx »
« #9 : July 23, 2009, 07:06:57 PM »
Had'nt asked myself the question yet :jt:
Mark Seele
« #10 : July 23, 2009, 10:03:47 PM »
JT, is that hole for the centre bolt i nthe middle?  Looks a little offset.  Maybe check against plate on bottom of axle where centre bolt goes in to check similar offset - that is if it is offset.  :-\
2006 LC 79 EFI
2000 LC 100 VX TD
1982 LC FJ 40
« #11 : July 24, 2009, 08:21:33 AM »
So you now have a chassis with springs and axles bolted back ?  :jt:
BTW that pic from TOYDIY is also correct  ;D
« #12 : July 24, 2009, 08:36:52 AM »
Mark I will measure, but I think it is an optical illusion.
Theo the pic from Toyodiy is opposite to what everyone else is saying.
« : July 24, 2009, 09:27:32 AM Jonathan Tee »
« #13 : July 24, 2009, 09:19:08 AM »
Look again, that pic shows the right front spring with narrow side to the front  ;)
« #14 : July 24, 2009, 09:20:53 AM »
That pic is the left front spring (PS) with the narrow to the front, however in that pic the straight side is on the inside, and not as per all the other pics.
: [1] 2
